TwinTurbo.NET: Nissan 300ZX forum - motor oil to lube the o-rings. Insert by twisting about 15°
Subject motor oil to lube the o-rings. Insert by twisting about 15°
Posted by doug8867 on June 19, 2006 at 4:25 PM
  This message has been viewed 44 times.
In Reply To 24 hours of Work Down the drain... posted by aztecz34 on June 19, 2006 at 03:50 PM
Message back and forth until you get the upper o-ring to barely show if at all. If the injector doesn't appear to be sliding in easily put a bit more oil on your fingers and lube it and the lower o-ring some more.
ps. Won't take you 24 hours this time. Always goes quicker the second time around.
